Original User: newbyprogerHello. I have 2 layers: one with polygons, another with text (annotation featuretype). I need to find if there is a label to each polygon. There is a part of code: Dim pPolygonsFCur As IFeatureCursor
Set pPolygonsFCur = pPolygonsFeatClass.Search(Nothing, 1)
Dim pPolygonFeat As IFeature
Set pPolygonFeat = pPolygonsFCur.NextFeature
Dim pTopoOperator As ITopologicalOperator
Set pTopoOperator = New Polygon
Dim pSpatialFilter As ISpatialFilter
Set pSpatialFilter = New SpatialFilter
pSpatialFilter.SpatialRel = esriSpatialRelIntersects
Dim pAnnoFCur As IFeatureCursor
Dim pAnnoFeat As IFeature
Do Until pPolygonFeat Is Nothing
Set pTopoOpeartor = pPolygonFeat.ShapeCopy
Set pSpatialFilter.Geometry = pTopoOperator.Buffer(500)
Set pAnnoFCur = pAnnoFeatClass.Search(pSpatialFilter, 1)
Set pAnnoFeat = pAnnoFCur.NextFeature
Do Until pAnnoFeat Is Nothing
If (pPolygonFeat.Value(iNameIndex) = pAnnoFeat.Value(iTextFieldIndex)) Then
'remember pPolygonFeat.OID
End If
Loop
Loop
1. What is wrong? pAnnoFeatClass.Search(pSpatialFilter, 1) doesnt give any result everytime2. Is it possible not to use Decimal Degree units in buffer? map units are meters.
