Python script that emails an attachement
1263
09-08-2014 07:56 AM
LouisEarly
New Contributor III
I had the following python script that sent out an email with an attachment.  It worked fine for the last 6 months then suddenly has stopped working.  Anyone have any ideas?
import smtplib
from email.MIMEMultipart import MIMEMultipart
from email.MIMEBase import MIMEBase
from email.MIMEText import MIMEText
from email import Encoders
import zipfile
import os
gmail_user = "xxx@gmail.com"
gmail_pwd = "password"
def mail(recipients, subject, text, attach):
    msg = MIMEMultipart()
    msg['Subject'] =subject
    msg['From'] = gmail_user
    msg['To'] = ", ".join(recipients)
    msg.attach(MIMEText(text))
    part = MIMEBase('application', 'octet-stream')
    part.set_payload(open(attach, 'rb').read())
    Encoders.encode_base64(part)
    part.add_header('Content-Disposition','attachment; filename="%s"' % os.path.basename(attach))
    msg.attach(part)
    mailServer = smtplib.SMTP("smtp.gmail.com", 587)
    mailServer.ehlo()
    mailServer.starttls()
    mailServer.ehlo()
    mailServer.login(gmail_user, gmail_pwd)
    mailServer.sendmail(gmail_user, recipients, msg.as_string())
    # Should be mailServer.quit(), but that crashes...
    mailServer.close()
mail(['xxx@williams.com'],
    "KMZ Update",
    "attached is the google earth update", r"C:\Users\user\Desktop\GEupdate.kmz")
DarrenWiens2
MVP Honored Contributor
What is the error message, if any?
Edit: the above script works perfectly fine for me, as it is.
LouisEarly
New Contributor III
Im not getting an error. The script just runs and nothing happens.  It simply says it's still running.
