Intro window
4057
09-08-2014 11:23 AM
ChristianSmith
I would like to create an intro widow in the tabbed viewer similar to what Bern set up in his PS caveloop stroymap.
http://downloads.esri.com/agol/pub/lavabeds/caveloop/index.html
  I realize I will have to edit the html css and js code.  While I feel I could piece this together over time through trial and error, I am wondering if someone has the snippets ready to go and would be willing to share them.
Thanks!
Smitty
MarkCooney
You can take a look at the source code and should be able to piece something together fairly easily.  Take a look at:
view-source:http://downloads.esri.com/agol/pub/lavabeds/caveloop/index.html
http://downloads.esri.com/agol/pub/lavabeds/caveloop/javascript/layout.js
MarkCooney
ChristianSmith
Thanks for the tip Mark. Between looking at the code and some bootstrap documentation I got it figured out.
JulieCarter
It would be great if you shared your discovery for future reference.
Thanks!
ChristianSmith
Hi Julie,
The reason I did not post a simple answer is that the work around I figured out involves editing the index.html, main.js and I created a custom css file as well. I am also pretty sure that my execution is not the cleanest way to do this.
If this is something you are interested in I am more then willing to share the code
