Export Feature Class to CAD
2139
09-05-2014 03:08 AM
hafidismaili
I'm new in Arcobject, and I have to convert a selected features to CAD drawing using just arcobjects and c#.the code below work good when i convert to a shapefile "ShapeFileWorkspaceFactory" but with the "CadWorkspaceFactory" it doesn't work.
any help will be greatly appreciated
public void featureToCad(){
IFeatureLayer fl = search_layer2(axMapControl1.Map, "parcelle") as IFeatureLayer;
        IFeatureClass pFC;
        IFeatureClassName pInFeatureClassName;
        IDataset pDataset;
        IDatasetName pInDsName;
        IFeatureSelection pFSel;
        ISelectionSet pSelSet;
        IFeatureClassName pFeatureClassName;
        IDatasetName pOutDatasetName;
        IWorkspaceName pWorkspaceName;
        // Get the featureclass from the layer
        pFC = fl.FeatureClass;
        // Get the Featureclassname from the featureclass
        pDataset = pFC as IDataset;
        pInFeatureClassName = (IFeatureClassName)pDataset.FullName;
        pInDsName = (IDatasetName)pInFeatureClassName;
        // Get the selected features
        pFSel = fl as IFeatureSelection;
        pSelSet = pFSel.SelectionSet;
        IWorkspace pScratchWorkspace;
        IScratchWorkspaceFactory pScratchWorkspaceFactory;
        pScratchWorkspaceFactory = new ScratchWorkspaceFactory();
        pScratchWorkspace = pScratchWorkspaceFactory.DefaultScratchWorkspace;
        // Define the output featureclass
       // give it the name of the input feature class + exp
  pFeatureClassName = (IFeatureClassName)new FeatureClassName();
  pOutDatasetName = (IDatasetName)pFeatureClassName;
  pOutDatasetName.Name = (pFC.AliasName + "exp");
  pWorkspaceName = (IWorkspaceName)new WorkspaceName();
  pWorkspaceName.PathName = "D:\\";
  pWorkspaceName.WorkspaceFactoryProgID = "esriDataSourcesFile.CadWorkspaceFactory";//it works with "ShapeFileWorkspaceFacto"
  pOutDatasetName.WorkspaceName = pWorkspaceName;
  // Give the output shapefile the same props as the input dataset
  pFeatureClassName.FeatureType = pFC.FeatureType;
  pFeatureClassName.ShapeType = pFC.ShapeType;
  pFeatureClassName.ShapeFieldName = pFC.ShapeFieldName;
  // Export selected features
  pExportOp = new ExportOperation();
  pExportOp.ExportFeatureClass(pInDsName, null, pSelSet, null,pFeatureClassName,0);
TimothyHales
Esri Notable Contributor
I've moved your post into the ArcObjects SDK space. You will get a much better answer here as the GeoNet Help is intended for community help and feedback. You can see more on the community structure, and what topics are under each space from the following documents:
GeoNet Community Structure
ArcGIS Discussion Forums Migration Strategy
Thanks!
Timothy
hafidismaili
thanks a lot
