Make netcdf raster layer problems
2791
09-04-2014 02:32 AM
KhaledTaalab
I have a NetCDF file containing daily rainfall data across Europe between 1995-2013 from the European Climate and Assessment Dataset (the file is too large to attach, it can be downloaded from http://http://www.ecad.eu/download/ensembles/downloadchunks.php‌)
The content of the NetCDF file is as follows:
netcdf file: E:\UCL\Italian_data\Rainfall\rr_0.25deg_reg_v10.0.nc  (NETCDF3_CLASSIC)
dimensions:
       longitude = 464
       latitude = 201
       time = 23376
variables:
       float32 longitude(longitude=464)
                 :long_name = Longitude values
                 :units = degrees_east
                 :standard_name = longitude
       float32 latitude(latitude=201)
                 :long_name = Latitude values
                 :units = degrees_north
                 :standard_name = latitude
       int32 time(time=23376)
                 :long_name = Time in days
                 :units = days since 1950-01-01 00:00
                 :standard_name = time
       int16 rr(time=23376, latitude=201, longitude=464)
                 :long_name = rainfall
                 :units = mm
                 :standard_name = thickness_of_rainfall_amount
                 :_FillValue = -9999
                 :scale_factor = 0.1
global atributes:
       Ensembles_ECAD=10.0
       Conventions=CF-1.4
References=http://www.ecad.eu\nhttp://www.ecad.eu/download/ensembles/ensembles.php\nhttp://www.ecad.eu/download...
I would like to use the 'Make netcdf raster layer' tool to create a multidimensional raster. I complete the boxes with input netcdf
variable - rainfall
X Dimension - Longitude
Y Dimension - Latitude
Output raster - name
Dimension Values - time
however, when I run the tool, the raster is created displaying rainfall from the most recent date (31/12/2013). when I right click on the raster, select properties and click on the NetCDF tab, time is in the 'Dimesion values' box but when I click in the box showing the date it does not have a drop down box of all other dates to select (e.g. 01/01/1995-31/12/2013) only the single date.
Any ideas what the problem is?
