Java error in ArcGIS Server 10.2.2
4426
09-02-2014 06:35 AM
jamesmuir
I am seeing some strange behavior each night with our ArcGIS Sever installation where it will throw the following error and become unresponsive.
Sep 01, 2014 4:03:06 AM ClientCommunicatorAdmin restart
WARNING: Failed to restart: java.rmi.ConnectException: Connection refused to host: 192.168.30.14; nested exception is:
  java.net.ConnectException: Connection timed out: connect
Sep 01, 2014 4:03:27 AM RMIConnector RMIClientCommunicatorAdmin-doStop
WARNING: Failed to call the method close():java.rmi.ConnectException: Connection refused to host: 192.168.30.14; nested exception is:
Sep 01, 2014 4:03:27 AM ClientCommunicatorAdmin Checker-run
WARNING: Failed to check connection: java.net.ConnectException: Connection timed out: connect
WARNING: stopping
I am still able to navigate to the the manager page, however, each service is listed as "stopping" or "stopped". Restarting the service for ArcGIS Server seems to resolve the problem until approximately the same time on the next day
We have tried re-installing but the problem is still reoccurring..
Has anyone run into this problem before and, if so, what did you do to resolve it?
-James
