ArcMap hangs on shutdown when debugging a .NET add-in
3575
08-28-2014 01:25 PM
JonathanBailey
I'm developing an ArcMap add-in using .NET and Visual Studio 2012. I've set the debugging option for the project to start ArcMap. Ordinarily, when I shut down ArcMap, I'm returned to Visual Studio and debugging stops.
EXCEPT when I open this one particular document in ArcMap. Then, I'm returned to Visual Studio, but the debugging process doesn't stop. The ArcMap process is still running and consuming about 50% CPU (on a 4 core machine).
If I run ArcMap by itself with the compiled add-in, ArcMap shuts down normally.
It almost seems like I'm hanging on to an unmanaged resource somewhere, but I created another map document that has content that causes the same objects to be created, and ArcMap shuts down normally and returns me to Visual Studio when I open this document.
I've also found that, when this occurs, the Dispose() method is not called on my add-in button.
Any idea why this is happening?
JonathanBailey
Agreed. This lead me to investigate whether the map document itself was a problem, since it didn't seem to happen with other map documents. I ran the map document through the MXD Doctor, and, problem solved.
JonathanBailey
Sol Wuensch‌,
I commented out the code so that it does literally nothing:
using ESRI.ArcGIS.Carto;
using ESRI.ArcGIS.Display;
namespace SpatialBridge.Addresses.ArcMapAddIn
    public sealed class FishboneCommand : ESRI.ArcGIS.Desktop.AddIns.Button
        public FishboneCommand()
        protected override void OnClick()
        protected override void OnUpdate()
        private void Events_ActiveViewChanged()
        private void OnActiveViewEventsAfterDraw(IDisplay display, esriViewDrawPhase drawPhase)
And the behaviour persists. Also, code analysis didn't find anything.
Jon.
RollinNelson1
Jonathon:
The only thing I would suggest is to use ReleaseComObject(if applicable).
In my case I created a geoprocessor in my .NET code. Then, my code kept hanging at "shutdown" after it ran successfully. Once I made the change, the execution was smooth and no hang-ups.
//Create geoprocessor
IGeoProcessor2 arankaGP = new GeoProcessorClass();
Marshal.ReleaseComObject(arankaGP);
OwenEarley
This is often the cause of these kind of problems. However, it seems odd that the problem persists with the ESRI.ArcGIS.Desktop.AddIns.Button boilerplate code and no user code.
JonathanBailey
