Geoprocesing Server With Dynamic Parameters as REST
2114
08-18-2014 05:03 PM
SheridanNava
Hello, am trying to publish a geoprocesig service from a model that creates .DAE files . the problem is when i publish the tool, i cant modify the parameters, so i tried publishing a geoprocesing service from a python script that make the same task, but i fail again, the parameters are constants and i cant modify them.
i would like to know if  is possible to have a gp service with modificable inputs, for example, if i had a shapefile input, i would like to pass "c:/myfolder/myshape.shp" as parameter.
this is my model.
this is my script
any help!
FilipKrál
It is certainly possible, although I am not sure if you can have intermediate output as a parameter of a geoprocessing service like the Multipatch Feature Class in your model. I guess it is important to make the distinction between input and output parameters.
I'd recommend adding Copy Features or Feature Class To Feature Class tool to copy the Multipatch Feature Class into say Multipatch Output, and making the Multipatch Output a Parameter instead of the Multipatch Feature Class (wchich will reside in some scratch workspace).
Similarly, you are missing arcpy.SetParameter in your python script to tell ArcGIS what to use as output from the script.
Hope this helps.
Filip
SheridanNava
Thanks. when i run on desktop the gptool acepts dynamic, like this.
but, when is arcgis server, there are no option to set parameter via rest.
OwenEarley
One thing to be aware of is that server GP Tools do not have as many data types available as the desktop tools.
Check out this ArcGIS Help 10.1‌ page for a list of REST geoprocessing task data types. There does not appear to be a data type supporting TINs.
XanderBakker
Esri Esteemed Contributor
Owen is right, TIN's are not supported as parameter in a geoprocessing service. In case the TIN's are pretty much static you could include them in your script, without being parameters. If you have multiple TIN's then you could provide some intelligence (for instance the extent) in your script to use those needed for the provided input featureclass.
Kind regards, Xander
