Arcpy - delete attribute data if string starts with..
5729
10
08-18-2014 02:12 PM
AliciaSoto
Here's what I'm trying to do.
I have a shapefile called 'Roster' with an attribute table like the one below.
NAMEAgeRoom
***John23B
***Alice56C
Tina34A
I would like to search the shapefile and delete any data under the field 'NAME' where the string starts with '***'
The resulting table would look like this
NAMEAgeRoom
23B
56C
Tina34A
I figured out how to replace the '***' string with another string, but I can't figure out how to delete the entire cell....
def removeName(shapefilePath):
  cursor = arcpy.da.UpdateCursor(shapefilePath, ["NAME"])
  for row in cursor:
       row[0] = row[0].replace("***", None)
       cursor.updateRow(row)
  del row
  del cursor
AliciaSoto
Thank you both for your help.
The code worked once I changed cursor.update(row) to cursor.updateRow(row)
Here is the final code
  for row in cursor:
    nameStr = row[0]
    if nameStr[0:3] == "***":
      row[0] = ""
  del row
  del cursor
CharlieFrye
Replace the contents of the for block with:
nameStr = row[0]
if nameStr[0:3] == "***" then:
   newName = nameStr.replace("***", None)
   row[0] = newName
   cursor.update(row)
CharlieFrye
nameStr = row[0]
   # This is if you wanted to just strip the ***
   row[0] = newName
   # set the string to nothing
   row[0] = ""
   cursor.update(row)
IanMurray
Honored Contributor
No need for the then Charlie
IanMurray
Honored Contributor
    for row in cursor:
      nameStr = row[0]
      if nameStr[0:3] == "***" :
        row[0] = ""
    cursor.update(row)
AliciaSoto
  for row in cursor:
    nameStr = row[0]
      row[0] = ""
  del row
  del cursor
JoshuaBixby
MVP Esteemed Contributor
Although I am thinking the UpdateCursor (arcpy.da) might still be faster, one could also use Make Feature Layer or Select Layer By Attribute followed by Calculate Field.  My preference is usually arcpy, but there are other geoprocessing ways of accomplishing the same task.
    arcpy.MakeFeatureLayer_management(shapefilePath, "shapefileLayer",
                                      ' "NAME" LIKE \'***%\' ')
    arcpy.CalculateField_management("shapefileLayer", "NAME", "str()", "PYTHON_9.3")
CharlieFrye
Thanks Ian--I've been writing VBA lately...
IanMurray
Honored Contributor
I figured it was something like that Charlie, no worries
RhettZufelt
MVP Notable Contributor
Another way to see if the name starts with ***
  for row in cursor:
    nameStr = row[0]
  if nameStr.startswith("***"):
      row[0] = ""
  del row
  del cursor
R_
