Get feature value for the selected feature - Java
3956
08-16-2014 10:22 PM
NajdALHanahnah
Dear All
I am working now to develop application by using Arcgis Engine 10.1 / Arcobject (Java) , i have connect to personal Geodabase (Mdb)  and i retrieve fields name layer name , fields properties (Geometry , type...) but when i try to retrieve information for the values (attribute value) i got null value .... i need your help to get the value in the fields ?
for example if i have (USA.mdb) personal geodatabase , layer name is : country , (fields : county name , country name , area) ....
what i need exactly to retrieve the county value from the county field  (California , Colorado... ...)
the below the code what i use it ....
and what is the different if i read the feature through (MXD file) or direct connect to MDB (personal Geo-database) the code will change or what i need you clarification please ....
IFeatureClass featureClass = featureLayer.getFeatureClass();
System.out.println(">>>+>>>>>"+featureClass.getAliasName());
// System.out.println(">>>+>>>>>"+featureClass.getFeatureClassID());
// System.out.println(">>>+>>>>>"+featureClass.getFeatureType());
IFields fields = featureClass.getFields();
System.out.print("+++++++++count  " +fields.getFieldCount());
// for (int i =0 ; i< fields.getFieldCount() ;i++){
// System.out.println(fields.getField(i).getName() + " - " + fields.getField(i).getDefaultValue());
for (int index = 0; index < fields.getFieldCount(); index++) {
//Get the field at the specified index
Field field = (Field) fields.getField(index);
if (field == null) {
System.out.println("Field is null ");
continue;
//Print out some metadata information
System.out.println("\tPhysical Name : " + field.getName());
System.out.println("\tAlias Name    : " + field.getAliasName());
System.out.println("\tType          : " + getFieldTypeDescription(field.getType()));
System.out.println("\tLength        : " + field.getLength());
System.out.println("\tPrecision     : " + field.getPrecision());
System.out.println("\tEditable      : " + field.isEditable());
//Default Value
Object defaultValue = field.getDefaultValue();
if (defaultValue == null) {
System.out.println("\tDefault Value : <Unspecified>");
else {
System.out.println("\tDefault Value : " + defaultValue);
System.out.println();
NajdALHanahnah
plz I need your support urgent ....
B.R
OwenEarley
I have only worked with .Net ArcObjects but this page has some information on working with fields using Java: ArcObjects Help for Java developers
The main difference I can see with your code is that field is declared as Field and not IField:
continue;
The ESRI sample on the help page declares field as IField (it is also declared before the for loop):
     // get the Fields collection from the feature class
     IField field;
     // on a zero based index iterate through the fields in the collection
     for (int i = 0; i < fields.getFieldCount(); i++){
        // get the field at the given index
       field = fields.getField(i);
       if (!field.getName().equals(field.getAliasName())){
            System.out.println(field.getName() + ":" + field.getAliasName());
