lock database schema
4377
08-14-2014 01:04 PM
Hernando_CountyProperty_Apprai
I would like to write a python program that loops through all of our arcserver map services and reports which one have lock database schema set to true.  Does anyone have any ideas how I would do this?  I don't see that the property shows up in json when I look at the rest service, it only seems to be in arcserver manager.  I would appreciate any help.
JakeSkinner
Esri Esteemed Contributor
Hi Priscilla,
You can iterate through each JSON file located in your 'arcgisserver\config-store\services' folder.  Here is an example reading a service named GovernmentServices.
import json
with open(r"C:\arcgisserver\config-store\services\GovernmentServices.MapServer\GovernmentServices.MapServer.json") as json_file:
    json_data = json.load(json_file)
    dict = json_data['properties']
    print dict['schemaLockingEnabled']
JakeSkinner
Hi Priscilla,
import json
Thanks Jake for your quick reply.  That worked great!
Here is the program that I ended up writing.  This actually edits the schemalock properties of all the services.
# For Http calls
import httplib, urllib, json
# For system tools
import sys, os, time, datetime, string
# For reading passwords without echoing
import getpass
# For sending email
import smtplib
from email.MIMEMultipart import MIMEMultipart
from email.MIMEBase import MIMEBase
from email.MIMEText import MIMEText
from email.Utils import COMMASPACE, formatdate
from email import Encoders
# Local Variables
messages=""
errors = "N"
now = datetime.datetime.now()
logFile = r"c:\Central GIS\EditSchemaLocks" + string.replace(time.asctime(), ":", "_") + ".log"
output = open(logFile, "w")
# Defines the entry point into the script
def main(argv=None):
    # Print some info
    print
    print "This script updates the lock schema property for every service"
    print
    # Open logfile
    output.write(time.ctime() + ":\n" +  "Starting Process..." + "\n\n")
    # Ask for admin/publisher user name and password
    username = raw_input("Enter user name: ")
    password = getpass.getpass("Enter password: ")
     # Ask for server name
    serverName = raw_input("Enter Server name: ")
    serverPort = 6080
    # Get a token
    output.write(time.ctime() + ":\n" +  "Getting Token..." + "\n\n")
    token = getToken(username, password, serverName, serverPort)
    if token == "":
        print "Could not generate a token with the username and password provided."
        output.write(time.ctime() + ":\n" +  "Could not generate a token with the username and password provided." + "\n\n")
        error = "Y"
        closeLogFile()
        return
    # Get a list of services
    output.write(time.ctime() + ":\n" +  "Get List of Services..." + "\n\n")
    params = urllib.urlencode({'token': token, 'f': 'json'})
    # The first list of services doesn't have a folder but does have a list of folder names
    servicesObj = sendRequest(params, serverName, serverPort, "/arcgis/admin/services/")
    if (servicesObj != ""):
        folderDetails = servicesObj["foldersDetail"]
        services = servicesObj["services"]
        editService(params, serverName, serverPort, services, "", token)
        # Now get list of services in each folder
        for folder in folderDetails:
            output.write(time.ctime() + ":\n" +  "Get List of Services for folder " + folder["folderName"] + "\n\n")
            servicesObj = sendRequest(params, serverName, serverPort, "/arcgis/admin/services/" + folder["folderName"])
                editService(params, serverName, serverPort, services, folder["folderName"], token)
    output.write(time.ctime() + ":\n" +  "Process Complete." + "\n\n")
    closeLogFile()
    return
# A function to generate a token given username, password and the adminURL.
def getToken(username, password, serverName, serverPort):
    # Token URL is typically http://server[:port]/arcgis/admin/generateToken
    tokenURL = "/arcgis/admin/generateToken"
    params = urllib.urlencode({'username': username, 'password': password, 'client': 'requestip', 'f': 'json'})
    headers = {"Content-type": "application/x-www-form-urlencoded", "Accept": "text/plain"}
    # Connect to URL and post parameters
    httpConn = httplib.HTTPConnection(serverName, serverPort)
    httpConn.request("POST", tokenURL, params, headers)
    # Read response
    response = httpConn.getresponse()
    if (response.status != 200):
        httpConn.close()
        print "Error while fetching tokens from admin URL. Please check the URL and try again."
        output.write(time.ctime() + ":\n" +  "Error while fetching tokens from admin URL. Please check the URL and try again." + "\n\n")
        error = "Y"
        return
    else:
        data = response.read()
        httpConn.close()
        # Check that data returned is not an error object
        if not assertJsonSuccess(data):
            return
        # Extract the token from it
        token = json.loads(data)
        return token['token']
# A function that checks that the input JSON object
#  is not an error object.
def assertJsonSuccess(data):
    obj = json.loads(data)
    if 'status' in obj and obj['status'] == "error":
        print "Error: JSON object returns an error. " + str(obj)
        output.write(time.ctime() + ":\n" +  "Error: JSON object returns an error. " + str(obj) + "\n\n")
        error = "Y"
        return False
    else:
        return True
# A function to send an HTTP Request
def sendRequest(params, serverName, serverPort, requestURL):
    httpConn.request("POST", requestURL, params, headers)
    # Read response
        httpConn.close()
        print "Could not read requestURL" + requestURL
        output.write(time.ctime() + ":\n" +  "Could not read requestURL" + requestURL + "\n\n")
        error = "Y"
        return ""
    else:
            print "Error when reading data. " + str(data)
            output.write(time.ctime() + ":\n" +  "Error when reading data. " + str(data) + "\n\n")
            error = "Y"
        else:
            # Deserialize response into Python object
            dataObj = json.loads(data)
            httpConn.close()
            return dataObj
# A function to Edit Service Properties
def editService(params, serverName, serverPort, services, folder, token):
    for service in services:
        if (service["type"] != "MapServer"):
            return
        serviceName = service["serviceName"] + "." + service["type"]
        if (folder == ""):
            serviceURL = "/arcgis/admin/services/" + serviceName
        else:
            serviceURL = "/arcgis/admin/services/" + folder + "/" + serviceName
        # Connect to service to get its current JSON definition
        serviceObj = sendRequest(params, serverName, serverPort, serviceURL)
        if (serviceObj != ""):
            # Edit desired properties of the service
            if (serviceObj["properties"]["schemaLockingEnabled"] == "true"):
                serviceObj["properties"]["schemaLockingEnabled"] = "false"
                # Serialize back into JSON
                updatedSvcJson = json.dumps(serviceObj)
                # Call the edit operation on the service. Pass in modified JSON.
                if (folder == ""):
                    editSvcURL = "/arcgis/admin/services/" + serviceName + "/edit"
                else:
                    editSvcURL = "/arcgis/admin/services/" + folder + "/" + serviceName + "/edit"
                params = urllib.urlencode({'token': token, 'f': 'json', 'service': updatedSvcJson})
                editData = sendRequest(params, serverName, serverPort, editSvcURL)
                if (editData != ""):
                    print folder + "/" + serviceName + " updated successfully"
                    output.write(time.ctime() + ":\n" +  folder + "/" + serviceName + " updated successfully" + "\n\n")
    return
# A function to close the log file and send it through email
def closeLogFile():
    output.write(time.ctime() + ":\n" + "Closing log file"   )
    output.close()
    #email notification
    server=<mailservername>
    msg = MIMEMultipart()
    msg['From'] = "arcgislicman"
    msg['To'] = <email address>
    msg['Date'] = formatdate(localtime=True)
    msg['CC'] = <email address>
    if (errors == "N"):
        msg['Subject'] = "EditSchemaLock Completed Sucessfully!"
    else:
        msg['Subject'] = "An Error Occurred in EditSchemaLock!"
    msg.attach( MIMEText(messages) )
    part = MIMEBase('application', "octet-stream")
    part.set_payload( open(logFile,"rb").read() )
    Encoders.encode_base64(part)
    part.add_header('Content-Disposition', 'attachment; filename="%s"' % os.path.basename(logFile))
    msg.attach(part)
    #tolist = ["pthoopthong@co.hernando.fl.us"]
    tolist = [<email addresses separated by commas>]
    smtp = smtplib.SMTP(server)
    smtp.sendmail("arcgislicman@co.hernando.us.fl", tolist, msg.as_string())
    smtp.close()
    return
# Script start
if __name__ == "__main__":
    sys.exit(main(sys.argv[1:]))
