'Is Null' in Python
11391
08-13-2014 09:59 AM
HemantAngarkar2
I am trying to use field calculator where values will be taken from one field of two fields with if condition. If first field is null then value will be taken from second field. In VB there is 'is Null' keyword. What is there in Python?
JasonScheirer
Esri Alum
You can use
value is None
For example, in your expression you can do
!field1! if not !field1! is None else !field2!
alternately just do
!field1! or !field2!
DanPatterson_Retired
JasonScheirer
Esri Alum
You can use
value is None
alternately just do
IanMurray
Honored Contributor
