Python script giving 'TypeError - Unsupported Type: Tuple'
10454
5
08-13-2014 06:39 AM
LanceWilson
Hello all - I'm pretty new to Python so I was wondering if anyone could please tell me why my script is returning the following error. Yes, I have looked up the error and its meaning, but am a little unclear on what could be causing it. Thank you in advance!
import arcpy
# Define the feature class
fc = r'C:\path\to\your\fc'
# find the unique 'SEGMENT_LENGTH' values
Slist = list()
for row in arcpy.da.SearchCursor(fc, 'SEGMENT_LENGTH'):
    # if the value isn't in the list then add it to the list
    if not row[0] in Slist:
        Slist.append(row[0])
for Value in Slist:
    # definition query to limit the rows in the cursor
    DefQ = 'SEGMENT_LENGTH = ' + str(Value)
    # Use a generator expression to populate a list from the 'QUANTITY_SOLID' field
    b = sum(row[0] for row in arcpy.da.SearchCursor(fc, 'QUANTITY_SOLID')),DefQ
    with arcpy.da.UpdateCursor(fc, ['QUANTITY_SOLID_SUM'],DefQ) as cursor:
        for row in cursor:
            row[0] = b
            cursor.updateRow(row)
I receive the following error:
Traceback (most recent call last):   File "example.py", line 23, in
<module>
cursor.updateRow(row) TypeError: value #0 - unsupported type: tuple
Failed to execute (SumFieldInsertNew).
ChristianWells
It looks like you are missing a right parentheses on your "b" variable.
#Current b variable
#This returns both the b variable and the definition query separated by a comma similar to a tuple
#Should be to return a value of b from a search cursor with definition query DefQ
b = sum(row[0] for row in arcpy.da.SearchCursor(fc, 'QUANTITY_SOLID',DefQ))
The original script has the definition query outside the parameters of the SearchCursor tool. Then when the "b" variable is called later on, it is read as a tuple instead of a single string/integer/float/etc. By moving the definition query inside the parentheses, it should return a value "b" from search cursor with definition query "DefQ". This should return a single variable instead of a tuple.
ChristianWells
#Current b variable
ChristianWells
Here is a picture showing the output when DefQ is outside the parameters.
LanceWilson
Great, thank you very much for breaking it down for me so I could understand exactly what was happening. I appreciate the help!
RiyasDeen
Looks like the your issue is at line 18.
This should be
LanceWilson
Thank you for your help Riyas!
