Change Local Services http default port.
3587
08-14-2014 07:49 AM
marceloctorres
There is a way to change the http port that ArcGIS Runtime uses to serve LocalServices content? Environment at customer network blocks default http port 50000.@marceloctorres ArcGIS Runtime SDK for WPF
Marcelo César Torres
MichaelBranscomb
Esri Frequent Contributor
Yes - run the LocalServerUtility app (shortcut on start screen or exe can be found in LocalServer bin folder).
Cheers
Mike
MichaelBranscomb
Cheers
Mike
marceloctorres
Thanks Michael, I try to force LocalServer use http por 80, but an exception throws "Failed to find open port from 80->80". If I change de range to 80-81 LocalServer use port 81.
Thanks again.
