webMap didLoadLayer snapshot mode
5131
5
08-12-2014 12:05 PM
KyleDunaway
This is the setup I have right now in an iOS app.
FeatureLayers are loaded from the webMap in didLoadLayer, and I set them to variables that I make changes to and push updates.
@property (nonatomic, strong) AGSFeatureLayer *myLayer;
- (void) webMap:(AGSWebMap *) webmap didLoadLayer:(AGSLayer *)layer
myLayer = (AGSFeatureLayer*)layer;
myLayer updateFeatures:@[featureImUpdating]
My problem is when I zoom in on a feature, the featureLayer only contains the features in the mapView, which I believe is onDemand mode?
If onDemand mode is the default for didLoadLayer, is there a way for me to change that to snapshot?
I would like to load all the features at once, instead of setting up queries.
Thanks for any help.
GagandeepSingh
Hi Kyle Dunaway‌,
There is a better way to approach this problem. When you instantiate an AGSWebMap object, the information/metadata about that web map is first loaded, which also include the `operationalLayers` property. Based on the information in the `operationalLayers` property the layers are loaded. `operationalLayers` property is an array of AGSWebMapLayerInfo objects representing each layer in the web map.
So once the web map has loaded, inside the webMapDidLoad delegate method you can run through each operationalLayer's layerInfo and change the `mode` property to `AGSFeatureLayerModeSnapshot`. Now the layers will load in the snapshot mode by default.
I believe right now you are loading each layer twice, first in OnDemand mode and then in Snapshot mode.
Let me know if you have any questions.
KyleDunaway
After webMap didLoadLayers was done, I loaded each layer I wanted in snapshot mode with
addMapLayer, and set the opacity to 0.
GagandeepSingh
Hi Kyle Dunaway‌,
KyleDunaway
So something like this?
- (void) webMapDidLoad :(AGSWebMap*) webMap
     for(operationalLayers in webMap)
          set mode to snapshot
     [self.webMap openIntoMapView:self.mapView]
Not sure on the exact syntax but is that the general idea?
EDIT:
     for(int i = 0; i < webmap.operationalLayers.count; i++)
          how to i access the layer
          webmap.operationalLayers.mode  = AGSFeatureLayerModeSnapshot
          i know this doesnt work, but something like this
GagandeepSingh
Here's a code snippet
-(void)webMapDidLoad:(AGSWebMap *)webMap {
    //change the mode on each layer
     for (AGSWebMapLayerInfo *layerInfo in layerInfoArray) {
        layerInfo.mode = AGSFeatureLayerModeSnapshot;
    [self.webMap openIntoMapView:self.mapView];
KyleDunaway
Sweet. Thanks man.
