addlayer error!!
9633
22
08-06-2014 01:58 PM
LefterisKoumis
I am new in python but this script should be easy to process. Instead I get:
arcpy.mapping.AddLayer(myDF,addlayer) NameError: name 'addlayer' is not defined
Here is the script:
import arcpy
thisMap = arcpy.mapping.MapDocument("CURRENT")
myDF = arcpy.mapping.ListDataFrames(thisMap)[0]
myLayers = arcpy.mapping.ListLayers(myDF)
for lyr in myLayers:
    if lyr.name == "CNNDB":
      addlayer = arcpy.mapping.Layer(lyr)
      print "got it"
arcpy.mapping.AddLayer(myDF,addlayer,"AUTO ARRANGE")
arcpy.CreateFolder_management(r"D:\GIS_data", "test")
arcpy.mapping.ExportToPDF(thisMap, r"D:\GIS_data\test\Project.pdf",300,"BEST",layers_attributes="LAYERS_AND_ATTRIBUTES")
#Do you see any errors?  Thank you.
XanderBakker
Esri Esteemed Contributor
Not sure what you are trying to do with this code. You loop through the layers in an MXD and check if the name equals "CNNDB". If that's the case you try to set a variable "addlayer". I don't think you should try to create a layer from a layer object.
Next you try to add the layer to the dataframe (where the layer already exists), although the code does not run that far. And you intent to export the map to PDF. Is the loop through your layer really useful?
Kind regards, Xander
LefterisKoumis
Ok, I modified my code....but I still getting an error.
What I am trying to do  is to loop through the layers of the current map and if a specific layer is found, then it will be copied onto a new map and then print the pdf of the new map.
Does it make sense?
import arcpy
newmap = arcpy.mapping.MapDocument(r"D:\GIS_data\test\new.mxd")
newdf = arcpy.mapping.ListDataFrames(newmap)[0]
arcpy.mapping.AddLayer(newdf,addlayer,"AUTO ARRANGE")
arcpy.RefreshTOC
arcpy.RefreshActiveView
arcpy.mapping.ExportToPDF(newmap, r"D:\GIS_data\test\Project.pdf",300,"BEST",layers_attributes="LAYERS_AND_ATTRIBUTES")
XanderBakker
I see you are trying to create a new MXD through python by just accessing a non existing mxd file in a just created folder. That will not work. See the blog post below with an example of using ArcObjects inside Python for that purpose.
Create a new MXD through Python.
This is rather complex. You might want to consider creating an empty mxd file and copy that file for creating a new MXD.
Luke_Pinner
MVP Regular Contributor
Is this your full code? Do you have any try/except clauses in there that might be hiding earlier exceptions?
I can't see how you would even get to `arcpy.mapping.AddLayer(newdf,addlayer,"AUTO ARRANGE")` as the `addlayer = arcpy.mapping.Layer(lyr)` would raise an exception anyway as `lyr` is a layer object, not a string.
Also, the AddLayer method will raise an exception as "AUTO ARRANGE" is an invalid value, it must be one of ['TOP', 'AUTO_ARRANGE', 'BOTTOM'] Note the "_" underscore in "AUTO_ARRANGE".
Here is some code to get you started:
import arcpy
if not arcpy.Exists(r"D:\GIS_data\test"):
templatemap = arcpy.mapping.MapDocument(r"D:\GIS_data\template.mxd") #an existing empty mxd
templatedf = arcpy.mapping.ListDataFrames(templatemap)[0]
myLayers = arcpy.mapping.ListLayers(myDF,"CNNDB")
if myLayers:
    arcpy.mapping.AddLayer(templatedf,myLayers[0],"AUTO_ARRANGE")
    templatemap.saveACopy(r"D:\GIS_data\test\new.mxd")
    newmap=arcpy.mapping.MapDocument(r"D:\GIS_data\test\new.mxd")
Notes:
  • arcpy.mapping.MapDocument requires an existing MXD, it can not create a new one. Use an empty mxd as a template.
  • You can pass a layer name (or partial name + wildcard *) to the arcpy.mapping.ListLayers method.
XanderBakker
Thanx Luke, for adding an example and the good explanation. This saves me some time
JamesCrandall
This is untested and I have not fully vetted this, but I think you can try to reference the path name instead of trying to add the layer from another .mxd.  You can use arcpy.Describe to get the fully qualified path of the layer:
import arcpy
      #set the path of the layer
      desc = arcpy.Describe(lyr)
      if hasattr(desc, "catalogPath"):
          addlayer = desc.catalogPath
#make a feaure layer to add to the new map
arcpy.MakeFeatureLayer_management(addlayer, "layernametocallit")
arcpy.mapping.AddLayer(newdf,"layernametocallit","AUTO ARRANGE")
arcpy.RefreshTOC
The addlayer variable is defined inside the for loop scope so it's not seen outside the loop, try to declare it before your loop then assign your matched layer to it.
LefterisKoumis
Sorry I am novice in Python. How do you declare a variable that if no layers are defined yet? Can I a declare without point at a layer?
Luke_Pinner
@Ahmed that is not correct.  For loops do not have their own namespace, so the variable is in the local scope. Consider this:
for i in range(2):
    loopvar = i * 2
print 'loopvar was defined in the loop and its value is {0}'.format(loopvar)
The above code snippet works fine and prints:
loopvar was defined in the loop and its value is 2
