Python Add-in missing
3603
7
08-06-2014 06:53 AM
MauricioSilveira
I programmed an initial add in in Python that works just fine. My problem is that when I make a trivial refactoring change to it, it fails to load in ArcGIS desktop.
The docs point to this being a syntax error in the code, but I checked it outside of ArcGIS and it worked just fine. I also couldn't find any information on ArcGIS (error logs, for example) about what the syntax error could be.
What can I do to find the cause of this problem? Can I find anywhere in ArcGIS a detailed error message about why this fails to load?
I post below how I refactored my code in case anyone can give me a hint about what could be wrong.
Before refactoring:
import arcpy
import pythonaddins
class Promedio(object):
     """Implementation for AddinsPyPromedio_addin.Promediobutton (Button)"""
     def __init__(self):
          self.enabled = True
          self.checked = False
     def onClick(self):
          #Compute average
After refactoring:
import arcpy
import pythonaddins
     """Implementation for AddinsPyAverage_addin.Averagebutton (Button)"""
     def __init__(self):
          self.enabled = True
     def computeAverage(self):
          #compute average
     def onClick(self):
          self.computeAverage()
JakeSkinner
Esri Esteemed Contributor
I believe the issue is do to the fact you have nothing under the 'computeAverage' function.  Try the following:
import arcpy
import pythonaddins
    def __init__(self):
          self.enabled = True
          print 'test'
    def onClick(self):
MauricioSilveira
Thanks Jake for your reply.
I apologize for the confusion. The code I posted was abridged for the sake of clarity. In place of the "#compute average" comment, I actually do the computation of the average. I include this code below.
Original code: (Working)
import arcpy
import pythonaddins
    def __init__(self):
        self.enabled = True
    def onClick(self):
        try:
            mxd = arcpy.mapping.MapDocument("CURRENT")
            layers = arcpy.mapping.ListLayers(mxd)
            print "Done, Done, Done"
            capaConseguida = False
            layerIntersection = layers[0]
            for lyr in layers:
                print lyr.name
                if "OutFeatures" in lyr.name:
                    print "IF"
                    capaConseguida=True
                    layerIntersection=lyr
            if capaConseguida==True:
                print "We got it"
                pathLayer=""
                try:
                    pathLayer = layerIntersection.workspacePath+"\\"+layerIntersection.name
                    cur = arcpy.AddField_management(pathLayer,"prommax",'FLOAT')
                except:
                    print "Something went wrong... An error ocurred..."
                print pathLayer
                fields = arcpy.ListFields(pathLayer, "", "")
                names=[]
                for fld in fields:
                    if 'min' in fld.name:
                        names.append(fld.name)
                    elif fld.name=="prommax":
                j=0
                with arcpy.da.UpdateCursor(pathLayer,names) as cursor:
                    for row in cursor:
                        suma=0
                        for z in range(0,len(names)-1):
                            suma = suma + row
                        resultado=suma
                        print resultado
                        row[len(names)-1]=float(resultado)
                        cursor.updateRow(row)
            arcpy.RefreshActiveView()
            arcpy.RefreshTOC()
        except Exception, err:
            print arcpy.GetMessages(2)
            print Exception, err
Below I include a trivial variation of the code above, factoring out a single line of code (line 18). This is a silly first step towards the very simple refactoring I described in my first post. This doesn't load in ArcMAP. Anyone knows why?
import arcpy
import pythonaddins
    def __init__(self):
        self.enabled = True
    def calculateAverage(self):
        return mxd
    def onClick(self):
        try:
            mxd = self.calculateAverage()
            for lyr in layers:
                print lyr.name
                    print "IF"
                    capaConseguida=True
                print "We got it"
                pathLayer=""
                try:
                except:
                print pathLayer
                names=[]
                for fld in fields:
                j=0
                    for row in cursor:
                        suma=0
                            suma = suma + row
                        resultado=suma
                        print resultado
            arcpy.RefreshTOC()
Thanks.
ToddUlery
You have setup to capture any error. That is good. So what are you seeing. Is the Add-in Installed, but just broken, showing no buttons or tools?\
Just to make sure, save a document with the Python window open. Then reinstall the addin - open the MXD and look at what the error says in the python window. Just a thought, not a solution to the problem.
MauricioSilveira
Thanks Todd for the answer.
As you said, I can install the Add-in perfectly but what I see is a borken toolbar icon.
I tried what you said but nothing happened, still couldnt see any errors
The image below is a screenshot of what I see.
falla.png.
Mauricio.
JakeSkinner
1.  Delete the Python add-in in ArcMap by going to Customize > Add-In Manager.  Select the add-in > Delete this Add-In
2.  Close ArcMap
3.  Run the makeaddin.py script
4.  Install the python add-in again
Your python syntax appears to be correct.  I was able to create an add-in, copy/paste your code, and the add-in worked successfully.
ToddUlery
can you also copy in the config.xml here.
When you see the the actual tool/button/* it can be a combination of things, but more than likely an issue with the config build not matching up with the python. I would just like to look over them both and make connections.
MauricioSilveira
Thanks Jake, I tried that too, but nothing changed.
Of course Todd.
Here it is.
<ESRI.Configuration xmlns="http://schemas.esri.com/Desktop/AddIns" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"><Name>Promedio</Name><AddInID>{06aee945-65c8-4cca-acd4-8fda0343d5d8}</AddInID><Description>Promedio</Description><Version>0.1</Version><Image /><Author>Promedio</Author><Company>Promedio</Company><Date>08/05/2014</Date><Targets><Target name="Desktop" version="10.2" /></Targets><AddIn language="PYTHON" library="AddinsPyPromedio_addin.py" namespace="AddinsPyPromedio_addin"><ArcMap>
    <Commands>
        <Button caption="Promedio" category="Promedio" class="Promedio" id="AddinsPyPromedio_addin.Promediobutton" image="" message="Promedio" tip="Promedio"><Help heading="Promedio">Promedio</Help></Button>
    </Commands>
    <Extensions>
    </Extensions>
    <Toolbars>
        <Toolbar caption="Promedio" category="Promedio" id="AddinsPyPromedio_addin.Promediotoolbar" showInitially="true"><Items><Button refID="AddinsPyPromedio_addin.Promediobutton" /></Items></Toolbar>
    </Toolbars>
    <Menus>
        </Menus>
    </ArcMap></AddIn></ESRI.Configuration>
Thanks!
