vb.net arcobjects spatial search sample
1552
08-05-2014 08:30 PM
LiYao
I want to perform a spatial search on ArcMap 10.2, cannot find proper sample for vb.net, what I found is the code from VBA. When I trying to convert it to vb.net, I encounter reference problem, the code is as following:
Public Function SpatialQuery(pFeatureClassIN As esriGeoDatabase.IFeatureClass, _
                             searchGeometry As esriGeometry.IGeometry, _
                             spatialRelation As esriGeoDatabase.esriSpatialRelEnum, _
                             Optional whereClause As String = "" _
                             ) As esriGeoDatabase.IFeatureCursor
        Dim pSpatialFilter As esriGeoDatabase.ISpatialFilter
        Dim strShpFld As String
        Dim pFeatCursor As esriGeoDatabase.IFeatureCursor
        Dim pQueryFilter As esriGeoDatabase.IQueryFilter
        ' create a spatial query filter
        pSpatialFilter = New esriGeoDatabase.SpatialFilter
        ' specify the geometry to query with
        pSpatialFilter.Geometry = searchGeometry
        ' specify what the geometry file is called on the Feature Class that we will be querying against
        strShpFld = pFeatureClassIN.ShapeFieldName
        pSpatialFilter.GeometryField = strShpFld
        ' specify the type of spatial operation to use
        pSpatialFilter.SpatialRel = spatialRelation
        ' create the where statement
        pSpatialFilter.whereClause = whereClause
        ' perform the query and use a cursor to hold the results
        pQueryFilter = pSpatialFilter
        pFeatCursor = pFeatureClassIN.Search(pQueryFilter, False)
        SpatialQuery = pFeatCursor
    End Function
Then I got the following errors:
Not sure is it because the library difference of ArcGIS version? or what kind of library missing in my vb file? what shoukd I do to make it work?
Thanks for your time.
OwenEarley
Hi Li Yao,
If you have added the ESRI references already then the types in your code would change from
To this:
Imports ESRI.ArcGIS.Geodatabase
pFeatureClassIN As IFeatureClass
or (without the Imports statement):
pFeatureClassIN As ESRI.ArcGIS.Geodatabase.IFeatureClass
Regards,
Owen
OwenEarley
You will need to reference the appropriate DLL files and then import the namespaces in your code file.
For example in Visual Studio - Add Reference:
Then in your code file import the required namespaces:
Imports ESRI.ArcGIS.Geometry
Public Class ExampleClass
     Public Function SpatialQuery(pFeatureClassIN As IFeatureClass, _
          searchGeometry As IGeometry, _
          spatialRelation As esriSpatialRelEnum, _
     ) As IFeatureCursor
        Dim pSpatialFilter As ISpatialFilter
        Dim pFeatCursor As IFeatureCursor
        Dim pQueryFilter As IQueryFilter
        ' etc ...
    End Function
End Class
Check out the ArcObjects namespaces page to find the appropriate DLLs to reference as well as the namespaces to import.
Hope this helps,
Owen
Spatial XP
LiYao
Hi Owen,
Thanks for your quick reply. But I have already imported the necessary reference in the namespaces.
OwenEarley
Hi Li Yao,
To this:
Regards,
Owen
LiYao
Hi Owen,
Yes you are right. Thank you very much for the patient to a beginner.
