MXD Won't Drop SDE Data Source - Problem with Map Service Publishing
1492
07-30-2014 06:23 PM
RandyKreuziger
I'm trying to publish an MXD on our production ArcGIS Map Server but the analyze keeps reporting that a data source is not registered with ArcGIS Server.  It thinks there is a layer coming from our dev database instance when after all of  MXD layers have been repointed to our production database instance.
I've used both the ArcCatalog - Set Data Sources and manually resourcing the layers but with no luck.  Has anyone seen were ArcGIS Server complain about a datasource that no longer exists in the MXD?  There are only about 8 layers in the map some of which contain Joins.  Do we have to manually redo the joins?
The data is in ArcSDE 10.1 SP1, SQL 2012.
Tags (1)
RandyKreuziger
After 2 and a half hours of messing with the MXD the original author discovered that he had to redo the joins even after we changed the data sources.  What a pain!  ESRI, your set data source function doesn't work when map symbolization is coming from an attribute in the joined table.
RandyKreuziger
