How we can make a group of layers?
8093
25
07-28-2014 11:08 AM
anjelinaponkerat
Hi
I have 32 layers in my flex application.Is there any way to make groups of these layers like ArcGIS Desktop?
I can not do this in ARCGIS DESKTOP, because some layers are cashed and some layers are dynamic.
Regards
AnthonyGiles
Honored Contributor
Yes, the config that is supplied with the widget works with the default config file when you download the viewer using the fires and demographic layers
RobertScheitlin__GISP
Anjelina,
   Many have requested this but it is not an option in Flex Viewer. There was a widget back several versions ago that sort of did this but it is not compatible with the current versions.
anjelinaponkerat
What is  the name of that widget?
If it is not compatible with flex 3.6, is there other solution?
Regards
AnthonyGiles
Honored Contributor
Anjelina,
the the source code for the widget can be found here:
WestonSF/ArcGISFlexViewerTOCGroupWidget · GitHub
but it will require you to have the ability to compile source code
Anjelina,
   Something like the group toc but no there is no solution for 3.6
anjelinaponkerat
Do you can help me more, or write a widget?
Angelina,
   Nope this one is way to complicated and involved.
anjelinaponkerat
I,m looking for a expert flex developer.  my email is:
anjelinaponkerat@gmail.com
anjelinaponkerat
I,m looking for an expert flex developer.  my email is:
AnthonyGiles
Honored Contributor
Anjelina,
I have recompiled the widget for 3.6 (attached zip file). You will not be able to use it with the web app builder so you will have to add the widget to the config file manually:
<widget label="Layers" right="10" bottom="10" preload="open"
                icon="assets/images/Legend32.png"
                config="widgets/TOCGroup/TOCGroupWidget.xml"
                url="widgets/TOCGroup/TOCGroupWidget.swf"/>
then amend the widget config for your layers it should be pretty much self explainatry
Regards
Anthony
