Given a rest endpoint to a MapServer, can we identify if the underlying data source is from fileGDB or SDE?
3593
07-28-2014 06:40 AM
WhereMatters
Is it possible to identify the workspace type (fileGDB or SDE) used in a map service?
Any specific property exposed by the REST API of ArcGIS Server that can help here?
AnthonyGiles
Honored Contributor
No, not that I'm aware of.
WhereMatters
Yes, I think so it may not be possible. Maybe there's an indirect way by using a WHERE sql query that works differently for fileGDB and an enterprise gdb?
AnthonyGiles
Honored Contributor
One difference I have seen in the SQL between a file geodabase and sqlserver is that a file geodatabase is case sensitive and sqlserver isn't.
EhabEl-Masry
if you cannot get this info it from the REST, make it a configuration value.
