ArcPy Script: Field Mappings Parameter and Object in Python Toolbox help
4394
07-28-2014 08:20 AM
BrianLai1
So I'm trying to create a Field Mappings input parameter for the ArcPy Spatial Join Analysis tool, but it spits up an error.  When I try to create a Field Mapping object in the execute portion of my test script, I can successfully add Field Maps objects to the Field Mappings object.  Below is an example of the error I get when trying to update the fields in updateParameters():
ValueError: FieldMappings:
AddFieldMap input not field map object
This is the code:
def getParameterInfo(self):
  targetfeatures= arcpy.Parameter(
       displayName = "",
       name = "",
       datatype = "Feature Class",
       parameterType = "Required",
       direction = "Input")
  fieldmapping= arcpy.Parameter(
       displayName = "",
       name = "",
       datatype = "Field Mappings",
  fieldmapping.value = str('Empty')                #If I don't include this line, I get an error: AttributeError: 'NoneType' object has no attribute 'addFieldMap'
  parameters = [targetfeatures, fieldmapping]
  return parameters
def updateParameters(self, parameters): #optional
  joinFeatures = parameters[0].value
  joinfieldmap = arcpy.FieldMap()
  joinfields = arcpy.ListFields(joinFeatures)
  for joinfield in joinfields:
       joinfieldname = unicodedata.normalize('NFKD', joinfield.name).encode('ascii','ignore')
       try:
            joinfieldmap.addInputField(joinFeatures, joinfieldname)
       except:
            pass
  parameters[1].value.addFieldMap(joinfieldmap)
  return
DanPatterson_Retired
is it because you are missing an extra bracket in this line?
should it be
fieldmapping.value = str('Empty') )
BrianLai1
That bit works just fine.  My field mappings parameters does have its default value set to 'Empty'.  The problem is in updating the parameter once I input a feature class.  What I want it to do is pull fields from the feature class and display them in my field mappings parameter.  Sorry I should I have mentioned that.
