Using SearchCursor and CalculateField
3131
07-28-2014 04:19 AM
BenLeslie1
Hi - I'm trying to write a little bit of code to assign a random value to my ORIENT field where ORIENT = 0.
My problem is that it chages the ORIENT for the whole table not just where the value is zero.
I guess that this is because line 14 does not refer to row but I don't know how to charge it so it does refer to row - can anyone advise??
import arcpy
fc = r"c:\Test_Orient.shp"
feildName = "ORIENT"
expression = "rand_num()*360"
codeblock = """def rand_num():
    import random
    return random.random()"""
#search for rows to be altered
rows = arcpy.SearchCursor(fc, fieldName + " = 0")
for row in rows:
    arcpy.CalculateField_management(fc, fieldName, expression, "PYTHON_9.3", codeblock)
ChristopherMoravec1
Ben,
It might be easier in this case (and probably faster) to simply us a feature layer and your calculate field.  I would try something like this:
import arcpy
    import random
arcpy.MakeFeatureLayer_management(fc, "TEST_ORIENT_LAYER", fieldName + " = 0")
arcpy.CalculateField_management("TEST_ORIENT_LAYER", fieldName, expression, "PYTHON_9.3", codeblock)
Using make feature layer makes an "in memory" pointer to the layer, much like adding the layer to an MXD does, it also happens to allow you to set a where clause.  Once you have this (I called it TEST_ORIENT_LAYER) then you can access it in almost any toolbox, as almost all of them take in a Feature Layer or a Feature Class (shape files included).  Check out the documentation here:
ArcGIS Help 10.1
As an aside, in my testing, until you want to calculate more than about 5 columns per row, it is faster to use a method like this as the Calc Field tool is faster than even a Data Access cursor until about 5 columns.  After 5 columns, you should probably open the cursor and do the calculations yourself.
ChristopherMoravec1
Ben,
import arcpy
    import random
ArcGIS Help 10.1
BenLeslie1
This one works for me.
Thanks John for your answer - looks pretty straight forward too - I will test it later as a learning exercise.
Cheers
JohnFell
Ben,
Rather than calculate the row you will benefit from generating an updateCursor object rather than using the CalculateField gp tool. I believe the data access module (arcpy.da) is more efficient. You can check out the links here, here and here for more information.
Import arcpy, random
from arcpy import da
fieldName = "ORIENT"
whereClause = fieldName + " = 0"
# create update cursor
urows = arcpy.da.updateCursor(fc, whereClause)
for urow in urows:
    urow.setValue(fieldName, row.getValue(random.random() * 360)
    urows.updateRow(urow)
