OSM Basemap
4189
07-24-2014 11:54 AM
EricPollard2
Just noticing the Open Street Map basemap doesn't seem to be in the basemap widget... any way to fix this?
Thanks!!
Eric
Tags (1)
ZhifangWang1
Unfortunately, missing osm is a bug of beta2, the only work round is to add it as an Item into Portal and using Lucas's way to add it to WAB.
LucasDorrough
I noticed that too, I think you can add it to the portal if you are using it
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
EricPollard2
Unfortunately I am not using portal, but regular AGOL. Thanks though.... maybe someone from ESRI can correct this on the AGOL end?
ZhifangWang1
