Replace Headers with Domain?
1206
07-15-2014 09:26 AM
TomHoober
I am trying to replace the headers of some tables I imported into a gdb.  I have a table that contains two columns that define the replacement I am trying to achieve.  I created a domain from that table for the gdb and than was hoping I could assign the domain to the fields but there is a problem.  The target fields imported as "double" type, which I want to preserve.  However, the values I want to change in the headers are text.  So currently the domain does not appear as an option for any of the fields (not surprising considering the types don't match).
Can anybody think of how to get this domain to work on the headers or will that never work?
DonOpgenorth
I've moved your post into the  Managing Data  space. You will get a much better answer here as the GeoNet Help is intended for community help and feedback. I have also added in a few additional tags. You can see more on the community structure, and what topics are under each space from the following documents:
GeoNet Community Structure
ArcGIS Discussion Forums Migration Strategy
Thanks!
Don
