Centering a map on android device
3167
07-14-2014 06:22 AM
EddiePabon_Vazquez
I'm creating an android application based on ArcGIS but dont know why the application does not open the data centered on the screen (map is not in the center of screen). Do you have any suggestions? Thanks
LukeCatania
call  initializeLayerOnStatusChangedListener(mapArcGISLocalTiledLayer) in your onCreate method passing the layer you want to center on your screen.  Set the mapView extent to that layer's full extent in the conditional block that checks to make show the map is loaded.
    void initializeLayerOnStatusChangedListener(final Layer arcGISLocalTiledLayer) {
         * Use OnStatusChangedListener to listen to
         * events such as change of status. This event allows developers to
         * check if layer is indeed initialized and ready for use, and take
         * appropriate action.
        OnStatusChangedListener onStatusChangedListener = new OnStatusChangedListener() {
            private static final long serialVersionUID = 1L;
             * This callback method will be invoked when status of layer changes
            public void onStatusChanged(Object arg0, STATUS status) {
                 * Check if layer's new status = INITIALIZED. If it is,
                 * set the extent.
                if (status.equals(OnStatusChangedListener.STATUS.INITIALIZED)) {
                    mapView.setExtent(arcGISLocalTiledLayer.getFullExtent());
        arcGISLocalTiledLayer.setOnStatusChangedListener(onStatusChangedListener);
