Error Creating SQL Server Spatial View
4522
07-09-2014 05:40 AM
JustinRay1
I seem to be having difficulty creating a spatial view in SQL Server.  The format I use is basically identical to the example in the Help, but I am getting this error:
Msg 102, Level 15, State 1, Procedure spvw_TEST, Line 2
Incorrect syntax near ','.
Does anyone know why it would be complaining about a comma (it is the first comma after "vw.FieldID" below)?  Here is an abbreviated version of the code I am trying to run:
CREATE VIEW spvw_TEST
AS SELECT (vw.FieldID,vw.Field1,vw.Field2,fc.Shape)
FROM vw_AllMain vw JOIN FeatsDistrib fc
ON vw.txtFeatID = fc.txtFeatID
Justin
ChristianWells
In this case, I believe that it has a problem with the parentheses. In this case, SQL Server is expecting an expression or subquery where the field names are. I was able to successfully run this query by first removing the parentheses. Can you try removing the parentheses and running it again?
AS SELECT vw.FieldID,vw.Field1,vw.Field2,fc.Shape
ChristianWells
JustinRay1
Well that worked like a charm; thanks!
I guess ESRI should consider revising their Help section here: ArcGIS Help (10.2, 10.2.1, and 10.2.2)
ChristianWells
Glad that I could help. I just submitted a ticket for that document to be reviewed.
