arcpy.RefreshActiveView
2818
06-16-2014 12:26 AM
JohnByrne
Morning all,
I am trying to put together a script that automatically updates the active table in Data Driven Pages. I found the script from one of the user groups on here and I think I have managed to alter the script but there is showing an error in line 39 and line 40
arcpy.RefreshActiveView()
arcpy.AddMessage("Process Completed")
Not sure what to do to fix this as I am only learning python and scripting. I have attached a jpeg of the code in case it helps,
Many thanks
DanPatterson_Retired
You are missing the closing bracket  )  in the line above hence it is erroring out
JohnByrne
Thanks Dan, silly error.
I am struggling to get the script to run and the problem seems to lay in my query and Search Cursor. It is giving me an error which says
  File "D:\Profiles\jByrne\Documents\DARD GIS\TEST SCRIPT\GridMon16_help.py", line 13, in <module>
    FP_sampleRows=arcpy.SearchCursor(GridTable.datasource, queryExp)
AttributeError: 'TextElement' object has no attribute 'datasource'
I have attached my code as well. I am running out of ideas and because I don't know it very well (started scripting friday!) I can't really see the wood for the trees.
import arcpy, os, sys
mxd=arcpy.mapping.MapDocument("current")
BUSID_TEMP=arcpy.GetParameterAsText(0)
LayersDF=arcpy.mapping.ListDataFrames(mxd, "Layers")[0]
selLyr=arcpy.mapping.ListLayers(mxd, "FP_sample", LayersDF)[0]
for elm in arcpy.mapping.ListLayoutElements(mxd):
    if elm.name=="GridTable": GridTable = elm
ddp=mxd.dataDrivenPages
arcpy.AddMessage(BUSID_TEMP)
pageID=mxd.dataDrivenPages.getPageIDFromName(str(BUSID_TEMP))
mxd.dataDrivenPages.currentPageID=pageID
queryExp="\"BUSID_TEMP\"='"+BUSID_TEMP+"'"
revTable=arcpy.mapping.ListTableViews(mxd,"GridTable")
AlexanderNohe1
Honored Contributor
Hi John Byrne‌,
It looks like the datasource attribute is not a property of that element.  I would recommend looking at the following documentation (ListLayoutElements (arcpy.mapping)) which can provide some insight into what each elements properties are.  The traceback error, which has the message: AttributeError: 'TextElement' object has no attribute 'datasource', lets us know that it is an issue with an attribute associated with a TextElement.  So we can look at our TextElement page and see that datasource is not an attribute of the textelements. Text Element (arcpy.mapping)
Does this help?
