build from the developer version of the playlist story map template not working
4303
7
05-19-2014 12:44 PM
SudhirPonnappan
I downloaded the developer version of the playlist storytelling template and followed the instructions for the github page. As suggested, I downloaded and installed the required software. When I go ahead and make a build, the contents of the built deploy folder and differ from the what was included in the original deploy folder.
On taking a closer look it appears that the javascript code is not being minified. It does not create the Playlist-viewer.min.js or the oldIE.min.js file.
I have attached a zipped deploy folder that was created from the build.
Any help would be greatly appreciated.
Thanks.
StephenSylvia
Try running this command:
npm install -g grunt-cli
then run the build command again. Note, the above command may require admin privileges (e.g. sudo on mac/linux).
StephenSylvia
Do you have all the required software installed (Git, Ruby, Node)?
Have you run the following commands in your project directory:
bundle install
npm install
Have you modified any of the JavaScript files? Do you get any errors in the terminal when you run the build command?
SudhirPonnappan
Thank you for your response.
Yes, I have installed the required software (Git, Ruby, Ruby Dev, Node JS).
Attached are the screenshot in a word document.
I have run the commands in the project directory and got no obvious error messages. I also changed the source code to limit the max allowablePoints to 5 and changed the renderer to be a simple renderer with a red marker icon. The changes are reflected when I run the command and check http://localhost:4567/
bundle exec middleman
[ATTACH=CONFIG]33928[/ATTACH]
The build is not being created correctly. Especially, the Playlist-viewer.min.js file is not being created. Not sure why.
Appreciate any help in this regard.
Thanks again.
StephenSylvia
Can you run the follow command in the terminal
bundle exec middleman build
Then save what get's printed to console and attach it so I can see if there are any errors.
SudhirPonnappan
Attached is the log. Thanks.
StephenSylvia
SudhirPonnappan
That seems to have done the trick. Could you please explain what this did to make it work?
Greatly appreciate you help.
Thanks!
StephenSylvia
You have to first have Grunt-CLI installed (seperate from the npm install) before you are able to access the grunt command in the project. I've update the GitHub readme to help other users.
