Summarize attribute table
5419
7
05-12-2014 05:09 PM
JuanIrarrazaval
Hello everybody! (sorry if this isn´t the right forum)
PLEASE. I have a problem and I can´t find the way to solve it! I´ve searched a lot... Here:
And that´s it, no other message
Thanks a lot
JohnPlunkett1
Hi
I just tried it myself without any errors. Attached
What version of ArcMap are you using?
Perhaps you could try save your work, quit ArcMap, restart your computer and try the process again
JohnPlunkett1
can you post the relevant data to the forum if possible please?
Then it could be determined what the issue is.
JuanIrarrazaval
Sorry, what´s the relevant data? I speak spanish and I´m a rookie in this
JohnPlunkett1
Sorry I meant the attribute table or shape file / feature class you are trying to summarize
JuanIrarrazaval
OK
I uploaded to my public folder on dropbox, its name is usos javi este. Hope i copied the shape the correct way
https://www.dropbox.com/sh/r9gcw8h4tbjlhjf/AABzAWSN2xXGtnrN19p_SA9ia
JohnPlunkett1
Hi
JuanIrarrazaval
Hi
ArcMap 10.1
Thanks a lot!!! I will try doing that, at least now I know the table is working... thanks!
JuanIrarrazaval
Hi
YEEEEEEEEEEEEEEEESSSS
I close and restarted my computer an nothing happened. Then, because it worked to you, I deleted the shape from the table of contents and add it again and it worked!!!!!!!!!!!!!
THANKSS
