problem while creating a geometric network in an arcSDE Gdb
2190
05-07-2014 08:52 AM
yousradaoudi
hello
i'm using arcgis server 10.1 workgroup edition and sql server Express 2008 , i find this problem (in the attached image) while i try to create my Geometric networkin my sde GDB
thanks for your help
[ATTACH=CONFIG]33650[/ATTACH]
WilliamCraft
From within ArcCatalog, right click the geometric network and go to Properties.  Post of screenshot of the General tab so that we can see which feature classes participate in the geometric network.  Please also provide a screenshot of the expanded feature dataset containing the geometric network while within ArcCatalog.  Also, which user account is being used to connect when attempting to create the geometric network?  Does that user have permissions necessary to create the network tables and accompanying database objects?
yousradaoudi
thanks for your answer i don't have any geometric network yet ,in the images you will find my dataset and in the second image you will find the classes that participate in my geometric network
[ATTACH=CONFIG]33802[/ATTACH]
[ATTACH=CONFIG]33803[/ATTACH]
