SyntaxError in Tool - Help to understand and correct that error!
880
04-13-2014 08:03 AM
RafaelRuas_Martins
Hi!
I've downloaded TBX and all the scripts to run some tools in ArcGIS 10.2.1.
First, I set the script file path and than I run to test all those tools.
For all of them, I received the same massage:
Executing: MinimumConvexPolygon D_VIVEK C:\Users\student\Documents\ArcGIS\Default.gdb\D_VIVEK_MinimumConvexPolygon 100 Fixed_Mean # #
Start Time: Sun Apr 13 12:48:38 2014
Running script MinimumConvexPolygon...
Failed script MinimumConvexPolygon...
SyntaxError: invalid syntax (HomeRange_MinimumConvexPolygon.py, line 1)
Failed to execute (MinimumConvexPolygon).
Failed at Sun Apr 13 12:48:38 2014 (Elapsed Time: 0.16 seconds)
I tried to run this exemple in python win, but it returned an error about "utils" module. It said "no exists"!!!
I checked on C:\Program Files (x86)\ArcGIS\Desktop10.2\arcpy\arcpy and there is utils.py file and utils compiled py file.
I'd like to understand and correct such systematic error in all of the codes.
Thanks for some help!!!
by Anonymous User
Not applicable
You just need to delete this part (first three lines of the script):
Python 2.7.5 (default, May 15 2013, 22:43:36) [MSC v.1500 32 bit (Intel)] on win32
Type "copyright", "credits" or "license()" for more information.
I think the author of this tool meant to delete this portion of the code.  This is the text that appears at the top of the Python shell window.
