Error in hyperlink script
1917
03-31-2014 05:26 AM
Zeke
Honored Contributor
I wrote a hyperlink script in Python for the Display tab. It has an if/elif structure based on the value of a field. With just the if clause, it runs fine an opens the document. But when I add the elif clause, Arc gives me an error saying '...name OpenLink is not defined'. This makes no sense to me, it's the default name of the function. Any ideas? Thanks.
import os, threading def OpenLink ([SubtypeCD], [Name] ):     if [SubtypeCD] == 'Recorded' and [Name] is not None:         parsedName = [Name].partition('-')         folderPrefix = parsedName[0].zfill(4)         fileSuffix = parsedName[2].zfill(4)         extension = '.TIF'         fileName = folderPrefix + fileSuffix + extension         loc = r"\\base\path"         image = os.path.join(loc, folderPrefix, fileName)         threading.Thread(target=os.startfile, args=(image,)).start()     elif [SubtypeCD] == 'Unrecorded' and [Name] is not None:         parsedName =[Name].split('-')         folderOne = parsedName[0] + '_Survey'         folderTwo = [Name]         fileName = [Name] + '0001.tif'         loc = r"\\other\base\path'         image = os.path.join(loc, folderOne, folderTwo, fileName)         threading.Thread(target=os.startfile, args=(image,)).start()       else:         pass         return
JoshuaChisholm
Hello Greg,
I might be as simple as a syntax error:
loc = r"\\other\base\path' should be loc = r"\\other\base\path"
Let me know if that does the trick!
JoshuaChisholm
Hello Greg,
benberman
I am also thinking along similar lines of Josh's suggestions.
Try changing loc = r"\\base\path" to loc = r'\\base\path'
Zeke
Honored Contributor
Yes, that appears to have fixed it. Dumb mistake on my part, but an even dumber error message. Thanks.
