Timeout issue when accessing Dynamic Map Service from Android Emulator
2873
03-20-2014 02:54 AM
GovindarajanThillaividankan
Hello
I am a novice in Android and got Eclipse Kepler configured with ArcGIS Android Runtime SDK 10.2.2. I have also configured Google ADT and all that is needed to run the HelloWorld example. I am using ArcGIS Server 10.2 Standard Edition on Windows Server.
I published a dynamic map service but did NOT enable the mobile access. I am told that it is NOT mandatory to enable the Mobile Access for a mapservice for simple viewing . Correct me if i am wrong. I published this Dynamic Map Service to Mobile Content server and able to access this from my SmartPhone using ESRI apps downloaded from Google Play.
Later I modified the HelloWorld example to point to a DynamicMapService. I included the simple code snippet below:
Pls note that i had replaced the servername/ipaddress with the placeholder tag.
 super.onCreate(savedInstanceState);
    // After the content of this Activity is set, the map can be accessed from the layout.
    mMapView = new MapView(this);
    //Envelope
    Envelope env = new Envelope();
    env.setCoords(21398, 14277.517116, 21528.702632172, 14340.018);
    mMapView.setExtent(env);
    //Dynamic Map Service layer
    mMapView.addLayer(new com.esri.android.map.ags.ArcGISDynamicMapServiceLayer("http://<ipaddress>:6080/arcgis/rest/services/Draft/CEM1/MapServer"));
    setContentView(mMapView);
When i access the URL of the map server in a browser in my laptop it works without issues. However when i run the Android app in Eclipse - installed in my laptop -  the Emulator starts, the apk file is getting installed but when the activity starts i am getting the error:
org.apache.http.conn.ConnectTimeoutException
However i am able to access this Mapservice from ArcMap in my laptop and my smartphone without  issues. I changed the Servername to IPAddress and back. When i click the Android App it opens and displays a black screen. However the LogCat displays the issue as shown in this message.
[ATTACH=CONFIG]32352[/ATTACH]
I am not sure where this is going wrong. I checked the following:
  • Map Service is accessible from ArcMap and Smartphone
  • Extent is valid  and has been verified in ArcMap
Can anyone help me in figuring out the problem? Thanks in advance.
Regards
Govind
GarrettMacKay
I am having a similar issue. Did you ever find a resolution to your problem?
