Programmatically Remove/Close catalog and search window from Arcmap
2919
03-06-2014 09:31 PM
kaustavroy
Dear friends
         is there any way to close catalog and search window Programmatically from the Arcmap.PLease guide me for this requirement
Thanks and regards
Deepak
ThavitinaiduGulivindala
These are called Dockable windows. Below link will help if requirement is to hide/show the Catalog/Search windows. There is a sample code and you simply need to input proper GUID/ProgID for Catalog/Search windows.
http://help.arcgis.com/en/sdk/10.0/arcobjects_net/componenthelp/index.html#/IDockableWindow_Interfac...
SanajyJadhav
Thavitinaidu,
Thanks for your help. I had the same requirement and I could fix it with your suggestion.
I am putting my findings here if anyone is interested.
The GUIDs of all dockable windows can be found in the registry at the following location.
HKEY_CURRENT_USER\Software\ESRI\Desktop10.2\ArcMap\DockingPaneLayouts\panestate\Pane...
And the code to remove the dockable window is as below.
                IDockableWindowManager docWinMgr = pApps as IDockableWindowManager;
                UIDClass pUID = new UIDClass();
                pUID.Value = GUIDValue;
                IDockableWindow pDocWindow = docWinMgr.GetDockableWindow(pUID);
                if (pDocWindow != null)
                    pDocWindow.Show(false);
S.
kaustavroy
Thank you very much sunjay
