Python. Simple script not working. Synthax error!!
1092
03-05-2014 11:52 PM
jenkelly
I am looking to redefine the average height attribute as either 1 or 2 story depending on their height. Any height less than 4 = 1 storey house and height above 4 = 2 storey house.
Please see screenshot of script. Have not used python much before and any help would be appreciated.
Thanks[ATTACH=CONFIG]31973[/ATTACH]
XanderBakker
Esri Esteemed Contributor
Hi Jen,
You're close. What is going wrong in your script is that in the definition of the  function you provide your field name, which contains a dot. What you  should provide is the name (any name) for a variable. In my example I  use "building_height" and "store_height".
As pre-logic script code you can use this (this includes logic for buildings that have more than 2 stories and being able to define the storey height):
def getStories(building_height, store_height):
    return "{0} storey".format(int(building_height / store_height) + 1)
The function is called like this:
getStories( !YourFieldName!, 4)
Please not that in this code 4 height units will return "1 storey", but 4.1 height units, will return "2 storey". I don't know if that is entirely correct...
Kind regards,
Xander
