Using a GraphicTracker with a DynamicMap
2311
02-26-2014 07:20 AM
ChristopherMeadows
I've been developing an add-in for ArcMap 10.1.  I am using a GraphicTracker to draw items on the map.  I have set the DynamicMapEnabled property of the map to true in order to improve the responsiveness of the map when drawing on the map at near real-time rates.  However, when I attempt to draw a polygon symbol with a solid fill it always renders as semi-transparent.  If I set the DynamicMapEnabled property to false, the polygon symbol renders correctly filled.  I've attached a screenshot to show what I am looking at.
Has anyone else seen this problem and know of a solution?
[ATTACH=CONFIG]31777[/ATTACH]
