Export to PDF Data Driven Pages
5862
5
02-06-2014 01:30 PM
MichaelDeseo
Hi, I'm new to Python and trying to write a script that will do the following:
1.  Loop through all mxd's in a folder and edit a Text Element named "SubTitle"
2.  Save the mxd
3.  Export each mxd to pdf
The problem is there are some mxd's with Data Driven Pages enabled, so I can't get the script to export ALL pages of a multi-page map.  I wrote an "if-else" so that I can distinguish the multi-page maps from the single page maps.  Everything else works fine except for the ddp map.
The error msg I get:
ddp.ExportToPDF(mxd, basename, "ALL")
AttributeError: 'DataDrivenPages' object has no attribute 'ExportToPDF'
See attached screenshot of the code.
[ATTACH=CONFIG]31200[/ATTACH]
ChrisPedrezuela
try ddp.exportToPDF
2.  Save the mxd
MichaelDeseo
Tried ddp.exportToPDF but no luck
ChrisPedrezuela
Did you use the correct inputs for that export function?
This small bit works actually,
if mxd.isDDPEnabled:
    ddp = mxd.dataDrivenPages
    ddp.exportToPDF(r'E:\test.pdf','ALL')
I have sample export code I did for my mxd's that are mixed DDP and normal ones:
for mxdDoc in mapList:
    mxd = arcpy.mapping.MapDocument(mxdDoc)
    base = os.path.splitext(os.path.basename(mxdDoc))[0]
    print 'Checking if DDP'
    if mxd.isDDPEnabled == False:
        pdfName = os.path.join(outPath, base +'.pdf')
        arcpy.mapping.ExportToPDF(mxd, pdfName, '', resolution=300, image_compression='ADAPTIVE', layers_attributes='NONE', image_quality='BEST')
    else:
        if mxd.dataDrivenPages.pageCount <= 3:
            for pageName in pageNames:
                mxd.dataDrivenPages.refresh()
                pageID = mxd.dataDrivenPages.getPageIDFromName(pageName)
                mxd.dataDrivenPages.currentPageID = pageID
                pdfName = os.path.join(outPath, base +'_'+str(pageName)+'.pdf')
                mxd.dataDrivenPages.exportToPDF(pdfName, 'CURRENT', '', 'PDF_SINGLE_FILE', 300, 'BEST', 'RGB',True, 'ADAPTIVE', 'RASTERIZE_PICTURE', False, True)
        del mxdDoc, mapList
del mxd
Also you don't need to do "for" statement to get your text element since there is a wildcard.
Just try,
x = arcpy.mapping.ListLayoutElements(mxd, TextElement, 'wildcard')[0]
MichaelDeseo
Thanks for your help, I was able to get the code to work.  I modified my inputs and you were originally correct in using 'ddp.exportToPDF' with the lower case 'e.' I had also changed to lower case 'e' in the else portion with the arcpy.mapping module but then kept getting an error there.  I guess there is a difference between 'exportToPDF' and 'ExportToPDF' when using dpp and arcpy.mapping, which is pretty confusing.  I also removed the 'for' statement like you said since it wasn't needed.
Below is the final code.  Thanks again!
import arcpy, os
from arcpy import env
Workspace = r"C:\Users\mdeseo\Desktop\PYTHON_TEST"
arcpy.env.workspace = Workspace
mxdList = arcpy.ListFiles("*.mxd")
NewSubTitle = "THIS IS THE NEW SUBTITLE"
for mapdoc in mxdList:
    filePath = os.path.join(Workspace, mapdoc)
    mxd = arcpy.mapping.MapDocument(filePath)
        basename = filePath
        x = arcpy.mapping.ListLayoutElements(mxd,"TEXT_ELEMENT", "SubTitle")[0]
        x.text = NewSubTitle
        mxd.save()
        ddp.exportToPDF(basename, "ALL")
        del mxd
    else:
        basename = filePath
        mxd.save()
        arcpy.mapping.ExportToPDF(mxd, basename)
        del mxd
print "Complete"
Tommy_KurniawanSubianto
hi michael. can this phython code be used? I've tried but eror
