Printing from Portal Map Viewer
4722
02-03-2014 06:25 PM
ZachChristoff
Here's another one...
When clicking the "Print Map" button from the map viewer the print page opens but never displays an image. Trapping the response I get this.
{"error":{"code":500,"message":"invalid code lengths set"}}
Note: Our portal is federated with IWA.
Anyone else having troubles with printing in Portal?
karenvolarich
The default print utility does not really work, it's better if you use your ArcGIS Server PrintTools service.  If you are an administrator in Portal you can go to My Organization-->Utilities and change the Print Service to your ArcGIS Server version.  I still have issues with map services behind security, but the basemaps work fine and will print KML, WMS, etc...
The URL you would use is:
???ArcGIS Server's preconfigured print service: https://webadaptor.domain.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%20Web%20M...
http://resources.arcgis.com/en/help/main/10.2/index.html#//017s00000028000000#ESRI_SECTION1_C094C0BE...
karenvolarich
