Map Gallery: Not showing map names on thumbnails
1818
01-31-2014 06:52 AM
JamesCucinelli
[ATTACH=CONFIG]31019[/ATTACH]
I would like to use the arcgis online map gallery application template.
but I noticed that the name of the map no longer shows up in the thumbnail.
Is this a new feature or a bug or an option that I'm missing.
I have attached a thumbnail of another web site which has the names and my current web site which doesn't.
Any suggestions would be appreciated.
James Cucinelli
JamesCucinelli
Kelly,
Nevermind, I got the answer.
It was default in 2.0.1 but now is not longer a feature.
I think it's important and hopefully someone will put it back in the most recent version.
James
KellyHutchins
Esri Notable Contributor
Are you using the Public Gallery template? If so it looks like you need to hover over the thumbnail item in order to see the map name. Here's an example:
http://www.arcgis.com/apps/PublicGallery/index.html?group=57096375507b4b068ef70e09f3417f12
JamesCucinelli
Kelly,
Thanks for the quick reply.
I see the hover functionality but a) that's not the way it was before and b) that's not showing what's going on this blog post from January 2014
http://blogs.esri.com/esri/arcgis/2014/01/06/using-and-customizing-the-new-gallery/
Can you help me figure out how to get that functionality working?
James Cucinelli
JamesCucinelli
Kelly,
James
