Layer in published service not visible
1189
01-16-2014 11:02 PM
BeraAkamole
I have a published map service with a group called 'Primarkata Leksand'. In the mxd i have a layer called 'Detaljplanerat_omrade'.
When i publish the mxd the layer is not visible in the tree of the published service but it is displayed on the map (even with the checkbox unchecked in the mxd). Service to the left, mxd to the right: [ATTACH=CONFIG]30601[/ATTACH]
I get the warning '20029: Layer's symbology is not supported (KML)' when i analyze the mxd before publishing. But as i said the layer is still visible in the map of the service.
Whats wrong?
nicogis
what's the version of arcgis server? In capabilities of service if you don't need kml you can uncheck KML capability (in map service by default, the KML capability is enabled)
