Python in Field Calculator - mod function
5733
01-16-2014 09:42 AM
Zeke
Honored Contributor
There are two fields in a topo line feature class, Elev for elevation and LineType10. I want to set LineType10 to 1 if Elev % 10 == 0, and 2 otherwise. The purpose is to be able to symbolize at ten foot intervals. I've got the code below, which doesn't give errors but also doesn't set any values. I've also used the plain % mod symbol. Any ideas why this doesn't run? Thanks.
Pre-Logic
def SetTen(elv, line):   if math.fmod(elv) == 0:     line = 1   else:     line = 2   return line
Window
SetTen( !Elev!, !LineType10!)
JoshuaChisholm
Hello Greg,
I'm not sure exactly why your code isn't working, but it might be good to simplify your code a little. First, you are calculating the value of LineType10, so you don't need to pass it as a variable to the function. You can also just return the value for line instead of setting and then returning a variable called line.
Does this work for you?
Pre-Logic:
def isTen(elev):   if elev%10==0:     return 1   else:     return 2
Expression:
isTen( !Elev! )
Also, just to confirm, LineType10 is a int field right?
JoshuaChisholm
Hello Greg,
Pre-Logic:
Expression:
isTen( !Elev! )
SurajBharati
The best website for Download Mod Apk for free
Zeke
Honored Contributor
Thanks, that worked great. Yes, LineTyp10 is an int. Much appreciated.
