Prevent Python script tool from automatically filling output boxes
1196
01-09-2014 08:50 AM
AustinMilt
I am creating a script tool as part of a Python Toolbox (.pyt) that performs some fairly basic tasks. The tool takes a single input file and creates three output rasters (see image). The problem I am having is that somewhere in Hidden ArcMap World, ArcMap is automatically populating the three output raster paths with the same path when the user gives the single input.
I have attempted to work around this in 2(+) ways.
  • by having a check in updateMessages that raises an error if any of the ouputs match path/name
  • by trying to automatically generate file names in updateParameters whenever the user has altered the input parameter (and the others dont yet have a "value" or have not been "altered")
How can I either [1] prevent ArcMap from populating parameter names without changing their status to "Optional" or [2] force ArcMap (or arcpy) to use different names when automatically populating those parameters?
[ATTACH=CONFIG]30378[/ATTACH]
PatrickJurgens
Please post the top portion of your code where you parse out the input parameters.
AustinMilt
Sorry, which part are you talking about? The execute() method?
# ~~ execute() ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ #
    def execute(self, P, messages):
        EXECUTE() calls ImpactScoreRasters.ImpactScoreRasters in Bungee's
        executing directory.
        pK = self.paramOrder
        import arcpy
        # process parameters
        analysis = arcpy.Describe(P[pK['analysis']].value).catalogPath
        outPad = arcpy.Describe(P[pK['outPad']].value).catalogPath
        outRoad = arcpy.Describe(P[pK['outRoad']].value).catalogPath
        outPipe = arcpy.Describe(P[pK['outPipe']].value).catalogPath
        usePadFootprint = P[pK['usePadFootprint']].value
Or are you referring to the getParameterInfo portion?
    # ~~ __getParameterInfo__() ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ #
    def getParameterInfo(self):
        """Define parameter definitions"""
        import arcpy
        # input analysis object (pickled file)
        analysis = arcpy.Parameter(
            displayName = 'Analysis Object File',
            name = 'analysis',
            datatype = 'File',
            parameterType = 'Required',
            direction = 'Input'
        # Output Pad Raster
        outPad = arcpy.Parameter(
            displayName = 'Output Pad Raster',
            name = 'outPad',
            datatype= 'Raster Dataset',
            direction = 'Output'
        # Output Road Raster
        outRoad = arcpy.Parameter(
            displayName = 'Output Road Raster',
            name = 'outRoad',
        # Output Pipe Raster
        outPipe = arcpy.Parameter(
            displayName = 'Output Pipeline Raster',
            name = 'outPipe',
        # Use Pad Footprint Flag
        usePadFootprint = arcpy.Parameter(
            displayName = 'Use Pad Footprint?',
            name = 'usePadFootprint',
            datatype = 'Boolean',
            parameterType = 'Optional',
            direction = 'Input'
        usePadFootprint.value = False
        # finish
        parameters = [
            analysis,
            outPad,
            outRoad,
            outPipe,
            usePadFootprint
        return parameters
