How to spatially sort line features???
565
01-08-2014 10:52 AM
YichiLiu1
Hi all,
I wrote a script to calculate angle bisectors of adjacent lines. I pasted my code here. This code worked fine if the line segments are in right order. However, if the features are not in a spatially right order, for example, the first feature (FID = 0, highlighted in the image) at the middle of the whole line, the result won???t be correct. My question is, how can sort these line segments? Or is there a better way to calculate angle bisector?
Thank you very much!
[ATTACH=CONFIG]30356[/ATTACH]
import sys
import os
import arcpy
import math
def CalculateAngle(x, y):
    Len = math.hypot (x, y)
    acos = x/Len
    angle = math.acos(acos)
    degree = math.degrees (angle)
    if y > 0:
        r = math.radians (degree)
        return r
    if y < 0:
        newdegree = 360.00 - degree
        r = math.radians (newdegree)
        return r
    if y == 0:
        if x >= 0:
            r = math.radians (0.00)
            return r
        if x < 0:
            r = math.radians (180.00)
            return r
inputlines = arcpy.GetParameterAsText(0)
fcLocation = arcpy.GetParameterAsText(1)
fcName = arcpy.GetParameterAsText(2)
dis = arcpy.GetParameterAsText(3)
d = float(dis)
arcpy.CreateFeatureclass_management(fcLocation, fcName, "POLYLINE")
arcpy.AddMessage("New Feature Class Created")
fcOutput = os.path.join (fcLocation, fcName)
# Create search cursor, read in lines
rows = arcpy.da.SearchCursor(inputlines, ["SHAPE@"])
#Insert Cursor: write lines to new feature lass
cursor = arcpy.da.InsertCursor(fcOutput, ["SHAPE@"])
#Read the first line
row = rows.next()
SLstartpt = row[0].firstPoint
SLstartx = SLstartpt.X
SLstarty = SLstartpt.Y
SLendpt = row[0].lastPoint
SLendx = SLendpt.X
SLendy = SLendpt.Y
STempX = SLstartx - SLendx
STempY = SLstarty - SLendy
#start the row iteration
for row in rows:
    lenth = row[0].length
    if lenth < 1e-03:
        continue
    ELstartpt = row[0].firstPoint
    ELstartx = ELstartpt.X
    ELstarty = ELstartpt.Y
    ELendpt = row[0].lastPoint
    ELendx = ELendpt.X
    ELendy = ELendpt.Y
    ETempX = ELendx - ELstartx
    ETempY = ELendy - ELstarty
    #Calculate the angle of first line
    Sangle = CalculateAngle(STempX, STempY)
    #Calculate the angle of second line
    Eangle = CalculateAngle(ETempX, ETempY)
    #Calculate the angle of bisector
    angle = Eangle + (Sangle - Eangle)/2
    cos = math.cos(angle)
    sin = math.sin(angle)
    TempX = d * cos
    TempY = d * sin
    StartX = TempX + ELstartx
    StartY = TempY + ELstarty
    EndX = ELstartx - TempX
    EndY = ELstarty - TempY
    array = arcpy.Array([arcpy.Point(StartX, StartY), arcpy.Point(EndX, EndY)])
    polyline = arcpy.Polyline(array)
    cursor.insertRow([polyline])
    STempX = (-1) * ETempX
    STempY = (-1) * ETempY
del cursor
del row
del rows
