workspace log errors
3755
12-19-2013 01:14 AM
ziadfilfili
Hello Matt
While opening the scene, a set of log errors are showing in my rules, some has to do with modern streets,some from lot inner.
Check attachment to have a better idea.
1- Is there a way to locate those errors that are connected to parcels, lots, streets, etc... ??
2- Any ideas why I have those errors ?
3- Does those errors affect in any way my export to Lumenrt ?
Thanks for your help..
Regards,
MatthiasBuehler1
These errors come up if you assign a rule that does not have a specific Start Rule to a shape with that defined Start Rule.
E.g.
If you have a shape with:
Rule File : a.cga
Start Rule : XYZ
But the content of a.cga is :
A -->
    B.
Means the rule XYZ is not defined in the rule.
This now means that you need to clean all cases where this happens. But that should not be too much work.
Ok ?
matt
