Use UpdateCursor to update field based on a change in another field
1701
11-18-2013 05:38 AM
JensenConnor
I am trying to update a field "TPN" based on another field "PASS_NUM". In my script "TPN" is a newly added number field and thus blank, "PASS_NUM" is also a number field but it contains the wrong numbers. I want to assign values to "TPN" when "PASS_NUM" is no longer equal the the value in the row above it. The feature class table is sorted by "PASS_NUM". See example of table I want to achieve attached: [ATTACH=CONFIG]29165[/ATTACH]
The PASS_NUM field does not increment by 1 each time (i.e. it may skip 7) but the I want to TPN to only go up one. Is this possible using the UpdateCursor in arcpy? Or is there another way to achieve this?
Thanks much!
DuncanHornby
MVP Notable Contributor
Jensen,
This can be done in a model or very quickly manually.
  1. Run your table with PASS_NUM through the Summary statistics tool and group by PASS_NUM
  2. Add a new field to this stats table called "X"
  3. copy the FID\objectID into "X", this is your incremental number
  4. Join the stats table to your table based upon PASS_NUM
  5. copy "X" into TPN
Duncan
MathewCoyle
Honored Contributor
Here is an example using an update cursor. Untested.
import arcpy
table = 'some_table'
last_val = None
count = 0
cursor = sorted(arcpy.da.UpdateCursor(table, ['PASS_NUM', 'TPN']))
for row in cursor:
    if row[0] == last_val:
        row[1] = count
    elif row[0] != last_val:
        count += 1
        row[1] = count
        last_val = row[0]
    else:
        pass
    cursor.updateRow(row)
JensenConnor
Matthew,
Thanks for your input. I think this code is very close to working for me. I got a chance to test it out and it throws an AttributeError: 'list' object has no attribute 'updateRow'. The line in question being cursor.updateRow(row). I will continue to play around with this and let you know if I figure anything out. Let me know if you have any ways around this.
Thanks again,
JensenConnor
Okay so this probably isn't the best fix but solved by using arcpy.Sort_management(inFeatures, outFeatures, ["PASS_NUM", "ASCENDING"]) and then removing the sorted tag before initializing the update cursor.
Thanks again for the input!
