Add a new item to the map context menu in ArcMap
4475
10-23-2013 07:29 AM
ChristopherMeadows
I would like to add an additional item to the map context menu in ArcMap 10.1.  Specifically the context menu when you right click over the map.  Here's a picture:
[ATTACH=CONFIG]28542[/ATTACH]
I found the following post (http://forums.arcgis.com/threads/40395-Need-ProgID-for-context-menu-properties-command) that talks about going to Customize -> Customize Mode and then selecting the Context Menus toolbars, searching for the context menu you want to modify and then getting its GUID from the registry.  However, I am not finding the above menu.  Have I overlooked something?  I can't believe this is one of the context menus that can't be modified.
Anyone else know what the GUID for this context menu is?
Thanks!
FrankVignati
Thanks!
the context menu you are looking for is the data view context menu:
[ATTACH=CONFIG]29129[/ATTACH]
DimaShats
ChristopherMeadows
I hope that you are looking for this:
http://resources.arcgis.com/en/help/arcobjects-net/conceptualhelp/index.html#//00010000029s000000
Thanks for the response.  I did find this before I posted and doing a word search for "context" didn't point me to the correct menu.  I don't think the menu I want listed here which must mean it is not configurable?
FrankVignati
Thanks!
ChristopherMeadows
Thanks!  I guess I overlooked this one when searching through all the context menus.
