manual selection as input parameter for a script
2760
09-20-2013 08:22 AM
oscarespitia
I  need a arcpy  script to process data from a selection, it's made manually in arcmap.
the selection is part of a mesh, to print data from a specified field.
Can i put a selection made ??????manually as input parameter for a script?
until now, I have a script that processes the selection stored in a layer that is displayed in the TOC
 #import arcpy module
import arcpy
# Load the MXD  default document
mxd = arcpy.mapping.MapDocument("CURRENT")
# Define the TOC default Data Frame
df = arcpy.mapping.ListDataFrames(mxd, "Capas")[0]
#access to the target (mesh selection), stored in a layer,
#By selecting the corresponding layer located on the TOC
fc = arcpy.mapping.ListLayers(mxd,"",df)[0]
#define of the field to consult.
field = "idMalla"
print "campo idMalla: "
# query  for reading  a specified field.
cursor = arcpy.SearchCursor(fc)
for row in cursor:
    print(row.getValue(field))
# delete memory
del mxd, df
[ATTACH=CONFIG]27638[/ATTACH]
