Model builder: iterative Excel-file import and Shapefile output
8327
09-17-2013 03:52 AM
EricWehner
Hi!
I'm trying to automate the following process within the model builder:
1. Import Excel xls-files, that each contain point elevation data with x,y and z values
2. Convert them into separate shape files while using the original xls file name as the output file name
Therefore I've setup the following model:
[ATTACH=CONFIG]27506[/ATTACH]
The problem occurs while trying to copy the features to an output shape when using the expression for the new file name. Since for iterating the Excel files I need to activate the Recursive option to scan the worksheets within each xls file. The extracted "File" then contains a "$" at the end to mark the worksheet (so if for instance the input file is 001b.xls, the extracted name within "File" is 001b$).
Because of the error message "000354 : The name contains invalid characters" i assumed that the "$" is the problem and used the Calculate Value tool with   r"%File%".replace("$","")   as an Expression and string as the Data Type. Unfortunately this doesn't help, although the calculated value seems to be correct (without the "$")...
Hence my questions are:
a) What exactly is causing the error and how can I solve it?
b) What other possibilities would I have to manipulate the input file name for output, for instance if I want to use only a part of the name or add an automated counter?
Thanks in advance for any help!
ChristopherBlinn1
Eric,
Are you sure the Calculate Value process is running prior to the Copy process? I understand you have a precondition but Model Builder can be tricky with preconditions at times.  I ask because I don't see the shade underneath the process as if it has ran.
A quick way to make sure of that is to delete and re-add the processes, adding the Calculate Value first, then the Copy.
As for your question regarding an automated counter %i% and/or %n% can be used to add the iteration number to a name.  Here's more information on these variables.
Hope this helps!
Best,
Chris B.
Edit:
Also it just occurred to me that you are naming a file starting with a number (at least in your example).  If you're storing this in a geodatabase, there will be naming issues for the file if it starts with a number.
EricWehner
Thanks for the hint (Calculate Value is now "shaded" too) - unfortunately it didn't have any effect. I think the order of the processes works according to plan, but for some reason the string I'm trying to create by "Calculate value" does not seem to have a proper format.
How would you create the output file name, if you wanted to base it on the input file's name?
Or is there another/better way to import 50 files (csv or xls) into point shapes?
Regards,
Eric
AkosKisreti1
First I would try to import the xls files into geodatabase tables. I experienced problems regarding xls tables.
Akos
