Dear community,
I'm a beginner with ArcMap and I'm working on administrative boundaries for my country. Anyway while editing the polygon I've accidentally moved it for a few cm/inches and saved the work without noticing it so I can't undo it. How to i glue it back with the existing vertices? I tried to move it manually with maximum zooming but even if they're aligned visually their vertices aren't glued.
Here's an example of the map:
[ATTACH=CONFIG]24738[/ATTACH]
Right click on the feature in your table of contents and export it.
Do your work on the copy of the feature.
Then paste the corrected feature into your good feature.
